I need a spark plug wire for a 1993 25hp Johnson Electric start. I look on MarineEngines.com (ME) and they show the OEM wire (which I assume is solid core stainless steel) which comes disassembled and they show different sizes of assembled wires from Sierra.
I tested the OEM wire I have and it has no continuity. It is an OEM spark plug wire, made with a stainless steel wire. I have some spare blue Sierra spark plug wires from another engine, and they are made of some non-metalic fiber that does not show continuity with a multimeter. I assume that these blue wires are the same as the blue offered by ME.
My question is how do you test those blue wires for resistance? How do I know they are good? Why would I need to switch from solid stainless steel core OEM wire to Sierra's blue fiber cord? I had some spare OEM wires that showed 2 ohms resistance and threw them away, as the manual said they should have zero resistance. Now if I understand correctly these new Sierra blue wires have resistance way above 2 ohms, and they are OK? I'm baffled.
