Spark plug wire
spicerak
Question if the spark plug wir
Question if the spark plug wire dosent make a good connection or it is bad will it screw up the spark plug.What will happen if the wire isnt good
If there is a break and arcing
If there is a break and arcing occurs it will burn and get worse until it fails completely.
It should not damage the plug although it may cause fouling if the plug is not firing properly.
It may however damage a CDI powerpack.
"How can i tell if a plug is b
"How can i tell if a plug is bad it seems like i have lost some power, i have changed all my plugs.Also i have had another priblem but engine worked with this problem but 2 plugs 1 in the middle and the one under. when i look at them they look like a dry look and the others have a nice oil look what do u think that is"
The reed valves for that cylin
The reed valves for that cylinder may be sticking broken or chipped or coil may be weak dies after running and you might be using the wrong plugs center carb adj etc
