Spark Plug Question
hgput17
Went to NAPA to pick up Cap, Rotor and Plugs...Champion manual listed RV12YC, which they did not have in stock. Cross referenced to NGK UR5, which I bought. Got home tonight and looked up my engine on NGK.com and they list BPR6FS, which appears to be a colder plug than the UR5. What gives?
1995 Crusader 454XL
Choosing the spark plug heat range is a choice whether to keep the plug hot enough at idle to prevent fouling and cold enough at maximum power to prevent pre-ignition or knocking.
I would use the colder plug. You will be running under a load more than you will be sitting idle.
