Spark Plug amp Impeller Questions
johntg
"I have a 2005 Merc 90HP ELPTO
"I have a 2005 Merc 90HP ELPTOSW.
Spark Plug - Is sticking with Merc plugs recommended? If going to an auto parts is ok store what brand and part number should I put in?
Impeller _ Same thought process, should I stick with Merc? If so do I need the whole kit or just the impeller. Part number would help please. If another brand is recommended which one and part number.
I always end up with the wrong part so if part numbers aren't to much to ask I would appreciate it. My first post so please bear with me. Thank you
John"
"John, you should stick with t
"John, you should stick with the NGK plugs that were engineered for your motor (BUHW-2) or your result may be quite disappointing.
You will find guys that will cross ref all kinds of numbers for you and say they are the same, but the resistance between plugs is DIFFERENT between the brands.
Merc and Yamaha ignitions throw out substantially more voltage than others, so use the correct plugs..."
Thanks Graham & Bandit for
Thanks Graham & Bandit for the advice on the plugs. NGK it is. How often do you recommend I change them and what gap setting? Have not changed them for a while and motor runs great.
Any advice on the impeller?
