This is the only thing I could come up with for you, Hope it helps you out some.
Below is a list of parts that would come in a Warm riser kit.
SEAWATER COOLED 119.38 MM (4.7 IN.)
WARM RISER KIT
Parts List
Qty. Description Part Number
2 Riser 119.38 mm (4.7 in.) 866208
2 Full-flow gasket 27-865786A01 (With turbulators)
2 Restrictor gasket 27-864850A1 (With turbulators)
1 Drop-down bracket 8637151
1 Screw, 1/4-20 x 5/16 in. 10-864378
6 Screw, 1/4-20 x 5/8 in. 10-860008
8 Screw, 3/8-16 x 1.0 in. 10-865982005
2 Pipe plug 3/4 in. 22-428611
And you may need A Supplemental Hose Kit.
IMPORTANT: Install the appropriate supplemental hose kit if applicable.
V8 MPI sterndrive models 865033A1
V8 MPI sterndrive models with multi-point drain (MPD) None needed
V8 MPI sterndrive models with 1 & 3 point drain 865035A1
V8 MPI inboard and tow sports models with inline exhaust 865035A1
V8 MPI inboard models with V-drive exhaust 865037A1
V8 carbureted inboard models with V-drive exhaust 865043A1
V6 and V8 carbureted sterndrive models None needed
V8 carbureted inboard models with inline exhaust None needed
So what should make it a warm riser kit is mainly going to be the design of the Risers, The design of the gaskets with using the turbulators on them, And the way you install the gaskets will play a part in the way it all works together.
So the "cool kit" should just be standard risers and gaskets.
By the way the part number you posted for the "cool kit" is 864306A5 You had it as 5A, I was
for a second.
Also if you wanted to see a Picture of the kit you can type in your part numbers in the link below and have a look at them.
http://www.mercruiserparts.com/partsByNumber.asp
