I been searching the web for an answer to the problem I’m having. I ‘ve seen similar posts but most indicate a cable problem which I don’t think mine is. So here’s my situation. I have a 1990 21ft Walk Around Cuddy with a 4.3 engine and a SP-C outdrive. We were out this weekend and the drive stuck in forward after going full throttle for about 10 minutes. This is the second time this has happened. The shift mechanism is stuck in forward and the engine wouldn’t turn over. When it happened the first time I removed the cable link and inspected everything thing, the shift mechanism would not turn manually until I tapped it and it broke free. I replaced the gear oil, did another inspection and reconnected the cable. I tested the shift mechanism on the trailer and it seemed fine. Forward reverse and neutral all worked without a problem. It seems to work fine until I run the boat at full throttle. When I did that it sticks again. Right now it is on the trailer the shift mechanism was removed and reinstalled and it is working freely. I don’t want to risk taking it out again and going through the entire process again. Any ideas.
