Good Morning all. I just joined this Web Site and here is my question and I am open to all suggestions as to why. Here is my issue. I just got a 1953 outboard, a Gale 5U10. I got it cheap because it was stuck. I got it home & messed with it just a bit and it freed up. I then checked the spark and had it. It would not start because the points were worn and out of time. I put in new points, set the timing and it started with the first pull. It does not keep on running, dirty carb (no problem in cleaning it) Here is the issue, After it sets for a while it gets "STUCK" again. I have never had an engine do this before. Note: It is the model that does have the "Clutch" and no reverse. I have not yet separated the lower unit from the Power Head to see if this will reveal which direction the problem lays. Any and all suggestions will be welcomed. Thank you in advance. Earl W.
