ifisherman
Howdy all.
I picked up a 2018 20hp four stroke tiller. It is on a small Carolina Skiff J14. I have had it out on the water a few times and it is a blast. I have a couple questions some more experienced boaters might be able to help with.
First off is the prop. So far the performance is solid as far as I can tell. It gets up and on plane pretty quick. Top speed with just me is about 24mph. Honestly I am happy. However I am curious, I am located in Colorado at about 6,000 feet. The prop I got is the one that came on the motor. Should I try out another prop or is it not even worth the effort?
In my manual it says to trailer the motor in the down position. I have plenty of clearance to do this but I wanted to ask if this is best. I want to make sure it is the right way to do it so curious any opinions out there.
When I do trailer the motor turns due to being in the down position. Is this bad? Is there a way to lock the motor so it can't turn from side to side when on the road?
Motor runs great. However after a couple hours on the water the motor will stall out. I will start it up and when I give it throttle it will bog down and eventually stall. I have to pump the bulb a bit and it fires up and runs fine. It is as if it just looses fuel for a second. I am curious about this and why it does it? Could it really be as simple as having to squeeze the fuel line bulb a bit? Seams odd that once it is all up and running and the gas tank is close to full it would do this. Maybe an air bubble in the line?
Last question is I have been running the engine out of gas when I am done. I pull the fuel line, let it run till it stalls. I won't go long between uses now the season is here. Probably using the boat every week or so throughout the summer. Do I need to run it out of gas?
Thanks all.
Thanks all.
