Is it OK to fill the unit with oil with the upper cap off.
After installing the lower this week I wanted to check the upper gears. While I had the cap off, I thought Why not dump oil in here till the upper screw gets covered.
I added the oil slow and saw and heard bubbles coming from the lower?
Seems like the air came out. Any thoughts on this?
I want new seals for the drain screws. Are O-rings from the local hardware store OK? or should I get the made flat rubber ones?
p.s. I know the washers go UNDER the screw head. LOL
