"I am rebuilding (first ti
"I am rebuilding (first time) two solex pai44 carbs, I purchased the totall rebuild kits and a seloc manual from this sight rolled up my sleves and took one apart as per what the book says, dunked the pcs into a bucket of acetone,let them soak over night to try to remove heavy coating of varnish.I cleaned all the parts carefully, so I am putting it back together and found a problem. The manual says to place the spring onto the diaphragm post then to position the diaphragm onto the carb surface with the post and spring faceing upwards. as per diagram how ever this is not the way mine were When I took it apart the spring was not on the post in fact it was not even on that side of the diaphragm it was between the carb body and the diaphragm I studyed the picture and it makes no sense to put the spring between the lever and the post the lever pushes the post but with the spring on the post it would keep the post and lever sprung apart.????? I am doing my first carb rebuild and reassembled the carb the way it came apart (spring under diaphragm) Is it possible I have it wrong or is the seloc book wrong? The other problem I found is the check valve that has the small screen, I found on one of the carbs it had no ball in it the triangle crimp on the end was partly broken enough to allow the ball out.Can I order two new ones is there a part number do they come with new screens? I was very suprised the carb kits did not have these parts in it. In the mean time the fix I put into place went as follows;first I needed to find a small enough ball that would fit into the check valve ....plug chain on the bath tub was cut mom-ma not overly happy but I told her I needed one ball, she tells me if I keep breaking the house up thats exactly what youll get! took the one ball off the chain filled it with solder rounded off as best I could installed it into the check valve then solderd a small pc of wire to act as a keeper. see pics. I dont intend to leave it like this and want to order two new ones asap.Can anybody help? Also want to replace screens.
can anybody help out with the uni-sink process I am trying to get the tool today as I would like to take the boat out one more time before winter Please help. It was recomended not to do the fuel pump but I allready had it off so I need a part number for the gaskit the motor is a 130c.
