Solex carbs 44PA1
obie8
Mine is dumping the much fuel
Mine is dumping the much fuel in the manifold. Would a kit sovle the problem and if so where's the best place to buy? Are there any tips on installing kit?
"A new float needle and seat w
"A new float needle and seat will likely solve your problem. The Sierra number for the carb kit is 18-7000. You can get them at the Marine Engine website, or you can order them through any marine parts store.
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-7000&returntopage= 80240774.htm
For carb overhaul instructions and tips, you may want to consult the Seloc manual for your engine and drive: the process is described step by step."
Is there a auto that uses this
Is there a auto that uses this same carb? The kit seems to be high priced compared to other carb kits. How good is this carb compared to like the Weber?
"Royze - carburetor tune kit
"Royze - carburetor tune kit # SO-68K
Gaskets, shutoff valve, accel.pump, air/fuel adjust screw w spring, washers."
