willow
Twin Crusader 1991 350s .......................10 hour trip..................5 hours into trip, (cruising at 1500 RPM) starboard engine RPM rolled back a couple of hundred RPM went back up and then rolled back about 300 RPM, then rolled back and engine quit, no noise, no backfiring,...................About 10 mins later I decided to try to start the engine .......I started the starboard engine, (started on first try), and it did the same thing after about 20 minutes of running. Did the same sequence about 6 times to get to destination.......FOR SOME REASON I CAN NOT GET THIS POSTING TO DROP TO A NEW PARAGRAPH....SORRY................. Anyhow...all fuel filters checked.....no problems evident....no antiphon valve on this boat................Tank 1/2 full of fuel...........I suspect COIL problem as the coil looks a bit rusty on the top.........new plugs, Dist Cap and rotor installed this year ........................The obvious sequence is to probably swap the coils between engines and see what happens but I would welcome any thoughts or other avenues I can explore should the COIL not be the problem....((The marina experts, (fellow-non-mechanical boaters) feel that the coil is slowly breaking down and when cooled it works again???))))............................................PS............. any idea why I can not start a new paragraph after I push ENTER??
