2001rotax800
So I am half way through my hunting season and have some serious motor issues. The other day while traveling wide open the motor hit hard and stopped, almost like the top end seized, but it fired right up again. I have been noticing the engine not reving up as high and having a "whine" to it, well the problem showed itself yesterday. The main shaft snapped just above the spline gear in the lower end.
I have dismantled the lower unit, surprisingly all gears and bearings look great with the exception of the thrust washer that sits above the pinion gear, and the shaft guide bushing. It appears that the play that developed allowed the main vertical shaft to wear groove and eventually allow the pinion to bind up on the gears snapping the main shaft.
2 Questions:
1. Anyone ever see this before?
2. I was able to press the lower shaft guide out, but I cannot seem to figure out a way to remove and replace the upper.
2 Questions:
