Smokeing evinrude fisherman 6HP
makayla010907
"I've got a 65 6HP that is
"I've got a 65 6HP that is smokeing a bluish smoke. You also have to run it with the choke about half way. I used a 50:1 fuel mixture. The motor will run wide open but smokeing. Would it be the rings, fuel mixture wrong or the carb."
Smoke is typical of a 2 stroke
Smoke is typical of a 2 stroke motor----- New oil is introduced into the motor via the gasoline---- after lubricating the engine for a while it ends up in the cylinder and is burned resulting in the smoke. Not to worry and it is NOT the fault of the rings.
If you have to keep the choke
If you have to keep the choke pulled out ----- the carburetor needs a good cleaning ----every dealer can get parts for that motor-----in outboard speak it is not " that old "
"As mentioned above in not so
"As mentioned above in not so many words, the carburetor is fouled and requires removing, cleaning, and rebuilding with a new complete carburetor kit.
The kit is most likely available on this site."
