Sluggish 65hp
boyle1770
"}<font face=""times new roman
"}<font face=""times new roman,times,roman"">Have a 1978 65hp 650Mercury Thunderbolt on a 16foot fiberglass Sunray. Under load the motor has full throdle but seems to have only 1/4 speed. I have a 12p prop. I would like to pull a tube, but not enough get go to do so.
Any suggestions what the problem could be??
Brother-in-law has a fiberglass boat with a 45 Johnson, and he outruns me. </font>
well it sounds like you have a
well it sounds like you have a smmall pitch on your prop i have a merc 500 and im running a 17 pitch but its also could be carb adjustments or dirty fouled plugs
but if you can try and get a higher pitch around 16 if your wanting to pull things and go fast enough at the same time.
"christian right on the prop b
"christian right on the prop but 12p could be ok if the diameter is large, also start with the basics, compression and spark then work on the carbs, trouble shoot first then spend some cash"
