Slow speed carb setting
Buck79
Hey guys I'm looking for some clarification on a carb setting issue. I have read several posts that relate to setting the S/S adjustments on my 71 Evinrude 50hp. What I'm specifically wanting to know is if a guy should be in forward gear when setting these. The local marine mechanic here tells me he makes all adjustments for slow speed in gear and that's how I should be setting mine. In the posts that I've read on here however don't say anything about being in gear. Which way is the proper way? Any help on the matter is greatly appreciated!
Those needle valve are slow speed adjustable needle valves. The high speed is controled by fixed jets located horizontally in the bottom center portion of the float chambers... way in back of the drain screws/bolts.
Adjust the S/S needle valves as follows.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2
: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Thank you joereeves for the instructions. I will take it from that guide that is a no to the motor being in gear for making the S/S adjustments!
