SLOW FUNCTION
coach_j
"IS THIS FEATURE INSTALLED ON
"IS THIS FEATURE INSTALLED ON A 93 88 HP EVINRUDE,? AND JUST WHAT HAPPENS WHEN IT IS ON,
THANKS"
I had 96 88 and it didn't
I had 96 88 and it didn't as far as I know. I think that started with the EMM controlled vs power packs. I think your engine has a upper and lower power pack. My upper went out once and it wouldn't get on plane but ran good at idle. My mechanic already changed stator trying to fix the problem but it didn't help. Hope this helps until someone more knowledged answers.
"i'm thinking,that 93 woul
"i'm thinking,that 93 would,have slow....it kicks down the rpm's,when an overheat situation occurs,and poss no oil to vro pump."
"thanks jwb, i wasn't sure
"thanks jwb, i wasn't sure. mine didn't have vro, i was mixing oil and gas. i am just going on what i was told on this one."
"THANKS, I KNOW MY DOSENT HAVE
"THANKS, I KNOW MY DOSENT HAVE THE VRO, I HAVE TO MIX THE GAS/OIL, BUT THE LAST TIME OUT IT DID KICK DOWN, TO A IDEL BUT I COULD BRING IT BACK TO NEAUTRAL, AND HIT IT AGAIN AND IT WOULD TAKE OFF AGAIN,FOR ABOUT 3/4 MILE AND REPEAT,BUT NO ALARMS MOTOR DONT SEEM TO BE HOT, GOOD HARD STREAM FROM THE T/T..JUST REPLACED WATER PUMP LAST YEAR...ANY IDEAS..."
just wondering if you have tri
just wondering if you have tried another fuel tank. i had a problem with a new tank that had a piece of plastic blocking the intake line. sounds to me like a fuel problem. air leak or bubble bad. just things to check before spending money. good luck.
"WELL THE PROBLEM FINALLY SHOW
"WELL THE PROBLEM FINALLY SHOWED ITSELF TODAY ON THE RIVER...BUT THIS TIME I GUESS IT GOT BAD ENOUGH FOR MY HORN TO GO OFF, SO I WOULD GUESS IT IS KICKING INTO THE S-L-O-W MODE FOR A REASON...I BELIVE IT MAY BE RUNNING HOT ON W-O-T SO I GUESS ITS TIME TO PUT A NEW WATER PUMP BACK IN, THIS ONE IS LESS THAN A YEAR OLD BUT NOT GONNA TAKE A CHANCE, THANKS GUYS FOR ALL THE HELPFUL IN-PUT"
