1988 OMC 4.3L V6 - Points Ignition, 2bbl Rochester Carb(amature rebuilt once, pro rebuilt once), New Long Block, Wing Manifolds, New Water Separator, Checked Fuel-OK Fresh this month, clean. 4yr old plug wires (they look marine), Age of coil unknown, New Points(readjusted and checked multiple times by 3 mechs and Condensor replaced. New Cap & Rotor last year(marine-brass), age of fuel pump unknown, anti-siphon is questionable but has been checked by mouth(no comments).
So.. last run yesterday my friend and boat owner says it ran the best it has ever but still has a "rolling" miss-fire at the upper 10% of the throttle, at that point running 4200rpm @ 33mph. Gets up on plane ok though does seem to lack a bit of power. we had issues that the timing wasn't coming back to what it was set on and don't have a timing light that is adjustable to we can't see the max. I want to get in there with a spring and weight set tomorrow, change the plugs ( R44T currently ), wires and Coil, and check the coil Voltage. Previously we sprayed fuel mix into the carb underload and it reacted as if it was too rich so I'm thinking this is electrical(spark).
My Main question is obviously thoughts about the cause of the miss fire and when a coil goes, can it provide a weaker spark then normal or does it just die?
Thank you in advance for your thoughts and assistance.
