SIEZED MOTOR
yachtie
"Yamaha,25 hp,4 stroke,long sh
"Yamaha,25 hp,4 stroke,long shaft, high thrust. Serial No.1024105 Purchasedsept.2005, installed March 2006, aprox 150 hours,all servicing done early, eg 100rs at 30.
Put boat on mooring, everything running fine (2 motors the same, one now faulty),shut down normal,4days later on return, one starts the other a clunk as starter motor engages, does not turn over motor. As a matter of course fuel was checked and filters replaced, so all ok, then sparkplugs checked, dry , no water ( first thought leaking head gasket), removed top cover, tried to start, as before starter engages no turn over, tried a big spanner on flywheel nut, doesnot move! Not in gear, prop spins ok.... surely not seized up, 'cus all was well on leaving!! These are run daily when on a cruise, just retuned from 6 months,although not for long periods, often calmdays or needed to get some where, thats all we can give any clues please?"
"Thankyou for your reply Just-
"Thankyou for your reply Just-in-time, No , No water in oil.Have since squirted WD40 in the plug holes and told to try bigger spanner, used 8" try longer! i nwas wondering if putting it into gear and try turning prop, a better leverage perhaps, gently that is! regards Tony."
"Thanks, I meant with the plug
"Thanks, I meant with the plugs out, rather attached to my fingers, just wanted to see if it would tun the motor over, regards Tony"
I would say one engine is seiz
I would say one engine is seized due to water ingression...could be from leaving it on a mooring and water up through exhaust? Could be a head gasket?
"Well, mechanic dropped by on
"Well, mechanic dropped by on way home and eventually found that the shaft from engine to gearbox had siezed at the head end.iT took alot to remove it, now waiting to reassemble !
thankyou all for your help,
regards Tony"
