"Hi,
Just got another proje
"Hi,
Just got another project boat (will I never learn?!), this time with a siezed 5.7 V8. Its siezed because previous owner left the bung in the boat when ashore, and it filled up to about spark plug / header level with rain water!
Anyway I have the headers off and some rusty water came out of 1 exhaust port, and on pulling the sparks plugs clean water (no rust) came out several of the cylinders. Obviously I am going to need to take both heads off, but just debating whether to do it in boat, or if really it needs to be craned out so I can also pull the sump to see if there is any corrosion in there. My gut feel is that the bottom end should be well enough coated in residue oil not to rust, and the oil level is about right so doubt its sitting on much if any water in the bottom anyway. The boat is at home so would have to get a crane / HIAB type truck in to lift it out.
Any thoughts (other than go get another engine, this one only has 250 hours on it, and is great apart from being siezed and full of water ;-) ).
The nut on the crank / balancer seems quite small (5/8 oR 9/16 from memory), so I am concerned about putting to much pressure on it to unstick engine (after soaking cylinders with oil obviously) in case it shears, would I be better to fix the (also siezed) starter motor and try that every so often instead to try to jerk it loose?
I am also confused as to how water got into cylinders, as there is no corrosion on any of the spark plug seats, or the exhaust port gasket.
Just trying to figure the best way to go about this before diving in....
Thanks,
Anthony"
"Hi,
Thanks,
Anthony"
