Ayuh,.... I use a right hand elbow, to good, 'n snug,.....what brand do you use
WOW, 4 posts and already so upettyThanks guys just trying to find some information but don't need your stupid ****
You will be better off buying an OEM merc than a cheaper aftermarket. I found on the gen one the sierra impellers lasted half as long as the OEM mercsI had a housing crack last year. I was lucky to get back without overheating. The faster I went the cooler it ran. Only thing I can think of why it cracked was it was overtightened.
If you want help dont go full Karen on people when you ask goofy questions. Are you really going to spend $50-75 on a low range inch lb troque wrench ? just snug it up. That's what is meant by a calibrated elbow...Thanks guys just trying to find some information but don't need your stupid ****
If someone asks a silly question such as this It makes you wonder if they have ever done any mechanical work on anything?You will be better off buying an OEM merc than a cheaper aftermarket. I found on the gen one the sierra impellers lasted half as long as the OEM mercs
As others stated likely cracked due to heat from the exhaust or lack of water flow. Wen was the last time it was changed.
I change the impeller every year and after they came out with the one piece housing I also change that every year. I thought the Sierra was a brand that was backed by OEM Merc. If not then may I will switch to Merc. I always try to stay away from 3rd part knock offs. Definitely was not an issue with lack of water. The impeller was fine when the pump was pulled out and replaced indicating to me there no water issue. As stated originally I was able to get back by maintaining higher RPM to keep the water temp down to me indicating that by running higher RPM was able to keep enough water in pump to compensate for the air being drawn in from crack.You will be better off buying an OEM merc than a cheaper aftermarket. I found on the gen one the sierra impellers lasted half as long as the OEM mercs
Did not view this as a silly question just asking how people are getting the proper torque per the specifications of 8-10 inch pounds as required per manufacturer.If someone asks a silly question such as this It makes you wonder if they have ever done any mechanical work on anything?
In industry such as small machine/medical instrument manufacturing, many assemblies use small screws and require specific tightening specs. Many use Inch/Ounce calibrated screw drivers...
But these parts aint medical instrument....lol
Merc and Quicksilver are the OEM brands. Quicksilver is the same OEM merc part with a slightly different part number so Merc can sell items outside their dealer network. Sierra is one of the better aftermarket suppliers some others are just plain junk. In my experience the merc impellers are worth the extra buck for them, would think the housing is the same.I change the impeller every year and after they came out with the one piece housing I also change that every year. I thought the Sierra was a brand that was backed by OEM Merc. If not then may I will switch to Merc. I always try to stay away from 3rd part knock offs. Definitely was not an issue with lack of water. The impeller was fine when the pump was pulled out and replaced indicating to me there no water issue. As stated originally I was able to get back by maintaining higher RPM to keep the water temp down to me indicating that by running higher RPM was able to keep enough water in pump to compensate for the air being drawn in from crack.
They aren't just snug it up. That's what people were trying to tell you... don't start cussing at folks when u needs some help otherwise you will get a bunch of wise azz answers with this crowd.Did not view this as a silly question just asking how people are getting the proper torque per the specifications of 8-10 inch pounds as required per manufacturer.
Obviously but I asked some dumb ones back in the day too.... but didn't give attitude while I was trying to find my ass with a flashlight and a mapIf someone asks a silly question such as this It makes you wonder if they have ever done any mechanical work on anything?
As I said in my first reply, ALL bolts/nuts have a torque specification.Did not view this as a silly question just asking how people are getting the proper torque per the specifications of 8-10 inch pounds as required per manufacturer.
