metal-chicken
Thread Starter
So my Honda 225 sit on a Bobs hydraulic jack plate that offers 6" of lift - the engine is currently as low as it can go on the plate (i.e. top holes on the engine). When the jack plate is at number 4 on the indicator (so it can go 4" further down and 2" up) the anti-cav plate is level with the lowest part of the hull - theoretically in the right place.
I do not have any performance issues due to engine height but it would be good to be able to lift the engine more than the currently available extra 2" to give the lower unit more clearance from the water when the boat is on its mooring as the very end of the LU does touch the water a little even when fully tilted.
I have an engine hoist that could lift the engine while I moved it higher on the jack plate so that's not a problem.
Does this make sense or am I missing something?
Thread Starter
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]
[/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]Thread Starter[/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif] [/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]Join Date: May 2016[/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]Posts: 137[/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]Default Should I mount my engine higher? (jack plate content)[/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]So my Honda 225 sit on a Bobs hydraulic jack plate that offers 6" of lift - the engine is currently as low as it can go on the plate (i.e. top holes on the engine). When the jack plate is at number 4 on the indicator (so it can go 4" further down and 2" up) the anti-cav plate is level with the lowest part of the hull - theoretically in the right place.[/FONT]
[/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]I do not have any performance issues due to engine height but it would be good to be able to lift the engine more than the currently available extra 2" to give the lower unit more clearance from the water when the boat is on its mooring as the very end of the LU does touch the water a little even when fully tilted.[/FONT]
[/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]I have an engine hoist that could lift the engine while I moved it higher on the jack plate so that's not a problem.[/FONT]
[/FONT]
[FONT=Verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]Does this make sense or am I missing something?[/FONT]
I do not have any performance issues due to engine height but it would be good to be able to lift the engine more than the currently available extra 2" to give the lower unit more clearance from the water when the boat is on its mooring as the very end of the LU does touch the water a little even when it's fully tilted up.
Sorry for the messy jack plate..... boat's being painted again in 3 weeks
