"I think the hardness of the &
"I think the hardness of the "hard" Rhino lining is probably only relative to their standard product which is pretty soft. I think it is still flexible, but I will be researching it before I ever commit that much time and money.
The regular Rhino lining is too soft. It would have to be sprayed on pretty thick in order to stand up to being dragged through the water all the time, whacking the occasional twig or whatever. (I don't hit the large stuff, but you can't avoid every twig.) That would make it heavy. It is also not real smooth, so would probably cause excessive drag.
I've heard of people spraying Rhino lining on the inside of the boat, but that doesn't seem worth the effort to me. As the rivets work loose the water will still enter around them. It won't enter the inside of the boat, but it will help corrode the rivets. A leaky seam will do the same. I'd just as soon keep the water completely out of the boat.
Having the lining on the inside of the boat will do nothing to prevent galvanic corrosion. That's a problem you probably won't experience unless you decide to leave your boat moored for the summer. My boat spends six months of the year in the water. When I pull it out there are little spots of corrosion here and there. Not a lot, but I don't like it. I keep putting on more zincs, but without completely plating the whole hull with zinc, I think I'll always experience this level of corrosion. If I was able to electrically isolate the hull from the water (with a layer of polyurethane) then it won't corrode.
I think powder coating is way too brittle to survive the world of boating. And spraying on more aluminum won't reduce the galvanic corrosion. Oh, another advantage of the Rhino lining is that the original paint does not need to be removed, just scuffed.
Probably the biggest questions I have about the Rhino linings are
1. Will they introduce drag?
2. Will more stuff grow on them than grows on the paint, and how hard will it be to clean off when I haul the boat?"
