New to forum!...about 5 months ago my salt water use engine was serviced w/o particular reason, it was just time (350 MAG MPI/Bravo III, 2004 SeaRay 260 w 220hours ), service included new impeller kit and thermostat. After uneventful 5 trips/15 hours or so I took it out and had the smartcraft engine overheating alarm after about 10 minutes of going in idle/minimum speed (<1500) rpm. Limped back to the dock at idle, temp never went higher than 220. Brother in law at dockside reports smoke coming from back of boat...
So engine ran at idle with overheating alarm on for about 10 minutes.
After raising the boat (lives on floating lift) a plastic bag floated from below the boat and washed on one of the pontoons. I didn’t pay any attention at the moment so I just went home thinking about having to call a mechanich after the holidays.
NEVER had an engine overheating issue before. Last week I flushed the cooling system as I normally do (muffler ears and hose with salt off). I run it on neutral at about 1200, wait for engine to reach temp then allow the salt off solution to circulate for about 5-10 min then shut engine off, then remove hose. Temp has always stayed nicely at 159F as usual.
Questions:
1. IF THE ISSUE WAS THE PLASTIC BAG COVERING THE WATER INTAKE AT THE DRIVE: is the recently changed impeller potentially damaged already?.
2. Any other parts that may need to be checked as consequence of ~10 minutes of idling the overheated engine?
3. What would be the potential source of smoke?...just overheated exhaust ?... rubber from impeller or a gasket being burnt?
Questions:
