Hi all. Fist post and I hope this is the right place to post it.
I have a 15hp johnson that I'm wanting to convert to a long shaft. I have found a leg extension with drive shafts and bolts. I know i need to extend the water pump pipe. What else do I need? I have seen that there are two different inner exhausts. One long and the one I have on at the moment for the short shaft. Can i use the short exhaust with the long shafts or will I do damage or won't fit? At times I may want to run it as a short shaft if I go away with a mate fishing inland in his tinnie.
Thanks all for your help
