HarrisonDawgs
Need some input. 2010 f225 sho blew the 10amp fuse on engine block that controls the electronic throttle. Originally happened when I was operating the trim up button on plane about 2800 rpm. Gone thru everything I can see and replaced the fuse several times but now it is blowing as soon and the high pressure fuel pump (in vst) comes on (sitting on trailer testing). Fuse for hp pump is located right next to the fuse that is blowing in the fuse block but no other fuses are blowing and the pump runs fine. Fuel pump was replaced about 4 months ago and has been perfect for about 25 hours of run time. Just hope someone here has some experience that may lead me to a solution. Open for any advice at this point. Also, boat is a Ranger with key touchpad, a known problem in the past but has been and seems to be functioning correctly. Thanks for any suggestions.
