I have a 1969 85 hp Johnson out board motor, and it is having some shifting troubles. I have full use of reverse and in order for the boat to go into foward gear, I put the shifter into forward and then I have to run the RPM's up on the motor and then it will slam into gear if you are in the water, now out of the water with a pair of water muff's hooked up to the motor it does the same. I have looked at the parts on this site for the shifting solenoids and they are both over $100, so I was hoping that someone on here may have some insight on what could be wrong with my motor before I just go ordering parts for it.
Thank you for taking the time to read this and I look foward to any information I may receive.
Sincerely,
Mike
Sincerely,
Mike
