"I have a 67 Johnson 100 hp wi
"I have a 67 Johnson 100 hp with electric shift control. When engine is cold it shifts into forward with a thump, no problem. But when everything warms up, it will only go into forward if I turn the engine off shift into forward and then restart the engine.
I have the proper "C" type oil in the lower unit. If I jump 12 volts directly to the green wire at back of motor there is no change. If I let the idle get so low it almost stalls, Sometimes it will slip into gear. Never with the force that it goes into reverse. Then I have to bring up the rpm's to see if it went into gear or not.
Am I looking at a weak coil or a worn out hub and spring. Has anyone out there seen this type of problem.
Thanks to Joe for prompt parts recieved for ignition problem.
Can any one out there HELP!!!!!!!!!!
JONATHAN ([email protected])"
