Hi guys, looking for an opinon. I have a 1996 Sunbird 2000 with a Volvo-Penta 4.3gs and SX Cobra outdrive, which I have run for 3 seasons. Engine is running good, but if I touch the shift/throttle lever in the neutral position, without depressing the detent, I get a single "ping" which sounds like a bell being struck. When I lift the detent and shift into reverse, it sounds like a "clapper type" firebell until the shift is completed (1/4 second). Idle is running at 800 rpm in the water, which I know is to high (550-650 rpm is spec). Oil level in the outdrive is fine. I haven't done anything yet, but I wanted to get some ideas before getting into it this weekend. Is there an adjustment at the OMC shifter/throttle control or just on the outdrive? The boat runs fine once in gear, but sounds like an ice cream truck when docking!
Thanks for your help!
