Shift shaft washer
birdy916
Hey guys. just got done replacing my sea water impeller and reading the instrctions says that there should b a shift shaft washer. looks like I am missing the darn thing correct? The rubber washer is still there jus missing the shift shaft washer? Thanks for the help! Gotta order it.
Also i've had the boat the past 4 yrs n have had problems shifting so we jus rock the shift arm to get it to gear and i've thought that it was my lower cable which i have purchased a new one, jus gotta replace it. but since the washer is missing can that b the problem it wont shift? jw. thanks
Yes ! you have to have the washer in place, it will not shift right if it's not there. Be sure the lower is in fwd and the upper shoe is straight ahead when putting upper & lower back together.
