clyde schroeder
Honda 10h.p. B100 The spool with the o-ring, on the shift shaft rod, I believe is stuck on the shift rod shoulden,t it be mounted securely in place in the round hole on the lower end and the rod slide through it. When you mount the lower end on does the shift rod get connected from up top? Clyde
