"Hello from Maryland....
I
I am swapping my lower unit on my outboard, a 1987 200GT -( J200STLCU Johnson 20" shaft) with another one I just got....the old one broke the shaft just above the bearing under the pump.
I was going to screw in my old shift rod and bottom it, counting the revs then put it into the replacement lower unit, bottom it and bring it out the same # of revs. to set it correctly..........but..............
Trouble is, while putting pumps on/off, I accidently unscrewed it several revolutions to take it out, thinking it was the useless replacement rod (brainfart ) and not needed... before I realized what I had done. Now, it is different than it was, so no use counting.
I searched back 9 pages on the forum... and I found listings for some, but not for my engine. Anyone able to help me with the measurement to use to the hole center to set it correctly prior to install?
And is the measurement taken w/ unit in neutral?
Many thanks. Greg"
I
Many thanks. Greg"
