Shift rod adjustment how much involved 115 2003
empiresunblack
"Hi, recently rebuit a 115 Joh
"Hi, recently rebuit a 115 Johnson 2003 2-stroke, engine completely put back together with no major issues, was on the final process of joining up the linkages and wondered why the linkage was not long enough, i failed to wind the shift rod in to the correct adjustment! obviously it is too high so needs to be screwed in
The question is when i remove the lever linkage and pin will i be able to twist the shift rod with my fingers or pliers or do i have to go deeper and remove the leg/powerhead etc!?
For some reason my manual fails me in this department so would anyone know what measurement it should be when in neutral?
look forward to hearing from you..
Matt, Rottnest Island, Western Australia"
"u wont be able to turn,u can
"u wont be able to turn,u can twist to align tho,shift rod height as follows----> Shift Rod Heights for 20" OMC-Bambardier Outboards*
CYL YEAR HEIGHT
2 1976-1988 20-29/32"
2 1989-UP 21-15/16"
3 1978-UP 21-23/32"
V4 C/F 1978-UP 21-27/32"
V4 Looper-Small 1986-1992 21-15/16"
V4 Looper-Big 1993-2001 21-15/16"
V4 60° Carb 1995-2003 21-1/4"
V6 C/F 1979-1991 22-1/16"
V6 Looper 1986-2003 21-15/16"
V6 60° 1991-2003 21-1/4"
V6 60° - F.I. 1998-2003 21-3/4""
"pull lower unit.///and adj ac
"pull lower unit.///and adj accordingly,if u have decided,to do this yourself,...i am assuming,..u have a factory service manual.......there IS,A REASON,they call us --PROFESSIONAL.--EXPERIANCE,professionalism,service literature,and gauranteed results........w/a warantee,....add it up."
