Shift question
luckycharms
"I have a 350 chevy with a VP
"I have a 350 chevy with a VP dp 290 outdrive. I went out for a spin today and decided to drift alittle when i re- started to go up river it started great but when I shifted to forward the shifter didnt engage and i was at throttle only. i brought it back to reverse and the boat just reved up. The shifter felt like something snapped because Before i had a little tightness from neutral to gear. So I threw anchor fearing the breakdown. One last attempt , I started again ,moved shifter to throttle position only reved engine brought it back to neutral moved it to forward gear and it was engaged. Off I WENT.... My question is what the heck happened. Gear shifter worked great back to marina...What would cause this. I cant see it having anything to do with the outdrive selector. It felt like it was in the Throttle selector position. Could it be when I first pulled the shifter back to Neutral to shut off and drift that it popped into throttle. It needs to be pushed out for Throttle. Iam lost...Any help I take greatly."
You may have to pull apart the
You may have to pull apart the control to find the answer. Something may be getting loose there (like the clamp holding the shift cable in place).
