Shift lever
outdoorjoe2
75hp mariner with a mercury sh
75hp mariner with a mercury shifter. Single lever with lock button and a nuetral button on the pivot. There is a run/off switch on the lower right with a plastic guard over it?????? There is also a plug on the top of the left side and I am wondering if this is for a safety shut off lanyard ?????? Thanks
Mark
"Man overboard switch? It is
"Man overboard switch? It is in the run position, does it need a lanyard to run or will it run without one?"
"if the switch is in the up po
"if the switch is in the up position the engine will run. Yes, that is a safty switch or man overboard switch. lanyard doesn't need to be attached until the local authorities pull you over."
