shawnfish
is there a trick to the shift lever adjustment? i loosen the clamp screw and adjustment screw (shifting in to reverse before i loosen screws) then turn the shift lever counterclockwise until the roller is all the way against the stop detent then tighten both back up. but when i check it in forward i can spin the prop 360 degrees, same with neutral and the dog engages in reverse and has a little play but you can feel some drag.
