99_baja_winder
1999 Baja Sidewinder 305 Alpha 1 Gen 2
My boat is factory equipped with individual throttle and shift levers.
Shifting into forward or reverse is like its between gears grinding.
It will go into gear after shifting from reverse into neutral and vice versa.
Do I need to adjust the shift cable mounted on the manifold or is there a adjustment under the shifter. Read many post on cable adjustments but not sure the same applied to individual throttle and shift levers? Thanks for your help.
