[email protected]
I have the lower unit off waiting for impeller, so I cannot tell if it's is engaging or not but I marked the shift linkage on the lower end.
When I engage f or r this linkage turneds almost 1/4 turn. One way in f and the opposite way in reverse. So I assume this would be enough to engage in the lower unit,
However my switch responsibile for cutting the engine temporarily when shifting, won't rock enough in f or r to activate the switch. The opposite of many people's problems where it gets stuck in the kill position.
The bottom cable seems to run through this switch an them to the shaft responseable for turning the lower unit shaft.
How can I adjust this.
I'll post pictures soon to show my issues
When shifting the first inch on my handle only rocks this interupter only slight out then back to center position, it's just not rocking far enough to engage my cutoff switch.
