I didn't know, so I asked Grok your question, and he said:
For a 1992 OMC Cobra with a 5.0L engine, the part number for the lower shift cable assembly is typically
987661 (replacing older part numbers 986654 and 987498). This applies to standard carbureted Cobra drives from 1988-1993 but may not fit some late-model 5.0L fuel-injected engines or other specific applications like King Cobra. Confirm compatibility by checking your existing cable or consulting an OMC parts catalog, such as on Crowley Marine’s website. Aftermarket options, like Sierra 18-2245 or Tungsten Marine kits, also reference these part numbers found on Amazon.
Yes, you must remove the outdrive to replace the lower shift cable. The replacement process involves disconnecting the cable from the transom bracket, loosening set screws, removing the cable retainer bolt, and accessing the cable through the transom. This requires detaching the outdrive, U-joint bellows, and exhaust bellows, as well as using tools like snap ring pliers and a shift cable adjustment tool (e.g., OMC 915271 or aftermarket equivalent). An OMC Cobra service manual is highly recommended for precise steps and measurements, such as setting the 7 5/8" cable length and bell crank alignment.
Special tools, including a bell crank alignment plate and shift cable tool, simplify the job, though it can be done without them with careful manual adjustments. Ensure the shift rod height and transom cable drag (max 2 lbs) are correctly set for smooth shifting.
https://grok.com/ Sign up for free.
