Shift cable adjustments on alpha 1 mr
skip1555
can anyone tell me how to adju
can anyone tell me how to adjust the shift cables it seems that i get it to go into forward but when i put it in reverse it dies because the roller switch moves and cuts it out
thanks
Is this a new lower shift cabl
Is this a new lower shift cable ?
A bad cable or built up corrosion will do the same thing tripping the switch.
no i just got done replacing t
no i just got done replacing the pump in the lower unit and when i put it back together i had full forward and neutral but no reverse so i trird adjusting the cables but once I put it in reverse it shuts down
"you installed the lower incor
"you installed the lower incorrectly,your off 1 spline.
control box in fwd, lower unit in fwd, slide up and insert the shift shoe to line upwith the upper shoe.Lined up correctly the shoes will be straight, inline , bow-to-stern,"
I dropped the lower unit and p
I dropped the lower unit and put it back up the shoe is bow to stern and I still just have foward and netrual as soon as i put it in reverse the engine shuts down and the switch is on the high cam shutting it down but if i take the cable off and push it all the way in it goes into reverse pull it out and it goes into foward .I looked at a diagrham of the cable but they don't look like my setup
