I was on the river today doing some carb 'tuning' with my '65 Johnson 18 hp FD-19 and it was running pretty good. I had just leaned down the HS needle and could tell I picked up a few more rpm so I made another adjustment but it didn't have any effect either way on the rpms. I throttled back to a slow trolling speed for a few minutes and then throttled up quickly. When I did the motor coughed and nearly simultaneously the motor revved up and I was going no where. Luckily I was only about a 1/4 mile from the dock and I paddled it back. (up stream of course)
Once at home I pulled the prop and found the shear pin had sheared. I am happy it was only the shear pin but now I have to question . . Is it uncommon for a shear pin to shear for such a mild motor sputter (cough / sneeze) or would it be fair to guess that the shear pin was already weakened over the years prior?
I have been told a shear pin is an item I should have as an 'extra' for such a time but I don't think I could have changed it with the minimal tools I had with me, it took some prying and pounding to get the prop off.
