I'm replacing the shaft seal on a 99' 50 hp Johnson (J50PLEEA) with the gearcase full of oil, motor trimmed completely up. The repair manual says to apply a light coat of gasket sealing compound to the bearing carrier o-ring flange and aft support flange when it's inserted back into the lower unit. As I'm looking down into the gearcase, the top third of the thrust bearing is visible in the gear oil. If I slide the bearing carrier back in with the gasket sealing compound on the o-ring flange, as the repair manual states, it will end up in the gear oil. This does not sound right. Has anyone else run into this before? I was trying to save the gear oil becuse it's less than six months old and shows no signs of water intrusion. Thanks!
