"I have been reading everythin
"I have been reading everything I can get my hands on about engine alignments. I get it now, the concept is not that complicated but no doubt will be tedious.
A recurring theme has been doing the alignment only after the boat has been in the water for a few days. My starboard shaft is almost centered but the port side is just touching the shaft log (1.25" shaft in a 2.25" log).
I don't see any wear though so I'm starting to think I should heed this advise. I also didn't have any vibration issues.
Without doing some before/after measurements there's really just no way to know how much the boat geometry has changed. Maybe the port side would be fine once it settled?
Al, I know you went through this but had shaft log wear which isn't true in my case. Did you do a rough alignment on the hard and then final in the water?
I really like "seeing" the shaft location now which of course I loose once the shaft log is installed. Finding the midpoint doesn't seem that difficult though.
Would you guys just wait and do it all at once in the water?
Bob"
Bob"
