"1st: Did PCM use Windsors or
"1st: Did PCM use Windsors or Clevelands in there marine engines? 2nd: What type of coil do I use to replace the existing coil. I go to the parts store and as soon as I mention Marine engine they get all in a tiz and scratch there heads. I ended up buying a generic 12 volt coil out of desperation. 3rd: I am having a problem with this motor. The engine runs like a champ up to about 1600 RPMs then labors and bucks, spits and hesitates at the 1600 RPM mark. I have totally rebuilt my holley 650 carb and replaced all of the ignition components. The results are always the same. It seems that the misfires above 1400 RPMs are on the right bank of cylinders. I acts to me as if it is starving for fuel, but I have about 7 pounds of fuel pressure at the pump. I am at my wits end and would greatly appreciate any help I recieve. Thanks in advance......"
