Ideally we be using a balancer that is professionally marked off, as shown here for a Std LH rotation engine.
(note that this one is also marked every 90*..... most likely for using the 8 stop cam follower adjustment procedure)
Or something like this where the numbers are actually machined into the surface.
The reverse of this would be used for a REV RH rotation engine.
With these markings, we don't need anything other than the
ZERO notch at the tab.
As for the PPS procedure....... rather than using 10* in either direction, try using something closer to 30* (could be 29*, could be 31*, 33* ... doesn't actually matter as long we adjust the pointer to come up with the same crank angle in either direction)
This gets us further away from top of stroke, and will give us a more accurate true TDC when the PPS is removed.
See post #12 in this recent thread on the PPS method.
The entire purpose of having these markings available, is to allow for higher RPM setting/checking of ignition advance.
We fire these on BASE advance, and we idle these on BASE advance... and that's about it.
Past this, our greatest concern will be our Ignition curve and Full-In RPM.
With the balancer marked off correctly, the Digitally Advancing type timing light now becomes Un-Necessary (a good thing in my book).
We can now use an ordinary strobe type timing light and see this in
"Real Degrees" in "Real Time".
In particular, take heed of Jeff's comment regarding your "24 btdc full advance came in early after 2000 rpms"
I agree...... this is too early for most V-8 gasoline Marine engines.
Timing a Marine gasser is nothing to roll the dice on, as an incorrect advance can cause Detonation.
Detonation can take out the tops of several pistons in a matter of minutes, and it not always audible, such as pre-ignition may be.
I'd find your OEM TA spec, and follow it.
As a rule only.... and for a SBC Marine Engine fitted with the full dished pistons, they can generally handle 26*-28* @ 3.2k RPM.
If Q/E built, this can be bumped to approx 28*-30* @ 3.2k RPM.
Again.... see your OEM specs to be safe, and always time your engine for TA.
BASE advance means little compared to this.
I'll be bold here and stick my neck out some......, but if we're using a mechanic that sets BASE advance only, and calls it a day, he's not the right guy to be tuning your Marine Engine.
Find someone who understands Marine load Detonation and Marine Ignition Timing, and have them do this for you.
