On my 1985 25 HP the timing instructions for the timing advance is to put boat in water,*put in gear and go full throttle and adjust timing advance link rod to*align*dots with*reference mark.* I have done this and secured both ends of boat to a concrete pier, and it's scary as h*ll.
If I take prop off (load removed from the motor)*and immerse motor in a water tank in my yard how much and which direction will I be off*as far as retarded or advanced?***By removing prop I've taking the load off the prop, but even still at full throttle it sounds like the motor is about to disintegrate.* I found out byleaving the prop on all the water is*immediately blown out of my tank.*
