Serpentine Belt on 50L slips off
jjtoth
"I have a 2007 Rinker 320EC wi
"I have a 2007 Rinker 320EC with twin 5.0L eningines with about 40 freshwater hours. The serpentine belt on the port side engine came off last year while cruising about 30 mph. The dealer replaced the power steering pump brackets after Volvo told them that they had an alignment problem with some of them, they also put on new belts with slices in them to eliminate a "chirping" noise they made at idle. The chirping noise was eliminated but the belt came off the port side engine again, causing the engine to overheat. Has anyone else had this problem?"
I believe there is a modified
I believe there is a modified water pump pulley available with ribs on either side to cure this problem.
paul
"Not too sure, you would have
"Not too sure, you would have to do some research to see whether you can get a non gen replacement. Probably wise to give volvo a call to see if you can get a part no., this should help with cross referencing to an equivelent part."
"My service guy is looking int
"My service guy is looking into it, I just like to make sure they're doing what they should to fix it, I'm a geek that way."
