Seized Powerhead
bradleyj
"Before I go ahead and order a
"Before I go ahead and order a rebuilt powerhead, can anyone suggest any other problems that could possibly explain this? While trolling, my port motor (175 HP 1999 Evinrude, 850 hrs, E175FCXEEN) started sounding very slightly different. Barely noticeable. After a minute or two, it just stopped. We tried to crank it and the starter was torquing because you could see the motor jump but the motor wouldn't turn. A handful of times it would turn maybe one revolution and then stop again. We tried it a few more times on the way back to port but it wouldn't turn. I was guessing a seized powerhead, and this morning I took the plugs out and put the lower unit in gear and I can't turn the prop by hand, so I'm still guessing seized powerhead. With the stbd motor that runs fine, I can turn the prop by hand while in gear without even taking the plugs out. Never had any warning lights so I assume it was getting oil and there are no codes in the ECU. Anything else I should check before I break out the credit card?"
"check the gear case ,make sur
"check the gear case ,make sure it turns freely ,you will have to remove it from the unit.
then check powerhead.if that does not turn then its time to pay up."
"Thanks. For what it's wo
"Thanks. For what it's worth, the prop spins freely in neutral and it shifts easily from fwd to rev."
"Brad, I agree with Charles, d
"Brad, I agree with Charles, drop the LU it could be busted clutch dog or something .."
I dropped the lower unit and i
I dropped the lower unit and it's fine. Definitely a seized powerhead.
The #1 plug was all black. All the others were clean. What is the potential cause of this powerhead failure? Cracked block or head? Failed head gasket allowing water into cylinder 1?
"Could be a number of reason&#
"Could be a number of reason's for this..
Clog carbs, failed vro, bad fuel, plug, overheat, wrong timing ..
The MOST important thing to know here you are looking at the symptoms of a failure you MUST find source of this failure if not you will be seeing the symptons again.
My power head failed simply because the previous owner or shop did not torque the rod bolts on the #4 cyl it came loose (both) and spun the bearing ..Symptons ? Knocking and rough idle, I shut her down pull the heads and bingo ..
url]
"If you are re-building it you
"If you are re-building it your self or needs a replacement check out this site ask for Vaughn is a very nice guy to deal with ,
Here is a picture of my power head from him excellent workman ship ..
http://www.powerheadexchange.com
<a href="http://s527.photobucket.com/albums/cc357/amackhrandilal/New%20Engine/?action=vie w&current=DSCF0002.jpg"" target="_blank"><img src="http://i527.photobucket.com/albums/cc357/amackhrandilal/New%20Engine/DSCF0002.jp g" border="0" alt="Photobucket"></a>"
"This is a Ficht?
Many pos
"This is a Ficht?
Many possibilities. If it hasn't receive the updates, it could have carbon'd up and scraped itself to death. You won't really know till you get it apart."
"Yes, it's a Ficht and it
"Yes, it's a Ficht and it has received all recall services including new pinned heads, etc. Never been to another shop since the recall service.
It was just the #1 plug that's black."
Oh boy....
He posts the model
Oh boy....
He posts the model number first thing...
E175 "F" CXEEN instantly says Ficht.
Ficht has NO VRO.
Ficht has NO carbs.
Dcramer is right on...this is a different animal... and you will have to diagnose it as such and treat the repairs as such.
"' Never been to another s
"' Never been to another shop since the recall service.'
Check the valves in the oil manifold.
Another possibility is the max obtained rpm has been to low. Think to remember it has to be about 5700 RPM. If no failure code in the ECU, it is just to start looking around. On the other hand, 850 hrs quite 'impressive' without trouble since the head change!"
"Hey Morton...
If you don&#39
"Hey Morton...
If you don't mind me asking...how did you get your Ficht training? With you being in where? Indonesia I think you said...do they have OMC schools over there, did you have to come back to the western world for schools...or did you self train with the manuals?
I am intrigued."
"WOT rpm has always been somew
"WOT rpm has always been somewhat low. Only about 5200 rpm. I've been meaning to have the props altered, but haven't done it yet.
By the valves in the oil manifold, are you referring to the manifold mounted to the top of the oil injector? I didn't realize you could take this apart. How do you check it? I see the normal puddle of oil in all six air inlet tubes, so I'm guessing all cylinders were getting oil, but I'd like to check this."
"Dough.
At the time the Ficht
"Dough.
At the time the Ficht's were introduced I still had my marina back in Norway. Went yearly to the old OMC factory in Belgium (Brugge). On top of that I was 'consulting' for the Norwegian distributor and conducted several service training sessions for other dealers in Norway at my place. Even 'certified' for the E-tecs before I left in 2004. Was quite busy around the bankruptcy times of OMC as I chose to stay 'loyal' and ride it through. Never brought a competitive brand into my shop, and it payed off. Have nothing against other brands, but i think it is better to know one 'good' than a little about many. At the moment I'm in fact using a Yamaha 40 Enduro!"
"Brad:
'WOT rpm has alway
"Brad:
'WOT rpm has always been somewhat low. Only about 5200 rpm. I've been meaning to have the props altered, but haven't done it yet.'
This may be your main reason for the breakdown. Another might be if you have never changed your impeller. This engine unfortunately lack a water pressure/temp SENSOR as input to the ECM. After a period of time the pressure drops and the temp curve of the engine relative to rpm is no longer as the one used for calculations in the ECM. This often results in a too rich mix at higher rpm with more carbon build up. When it comes to max rpm that is even more important. If you do not get the recommended rpm, you simply 'overload' the pistons and bearings. oil-film gets too thin and weak, and pistons seizes up or bearings fails."
I did the water pumps on both
I did the water pumps on both these motors about 200 hours ago. I'll definitely need to take care of the props. Thanks for all the advice.
