Seawater pump AQ145A
gryg1
does anybody know where i can
does anybody know where i can get a exploded picture of the seapump that shows the seal and bearings in it .thanks
"If you have a Johnson pump, t
"If you have a Johnson pump, this is a good link:
http://www.johnson-pump.com/JPMarine/products/enginecooling/index.html
The expoded view in the parts list is generic because the pumps in the specific class are pretty much put together the same. Not hard to figure out what goes where. Also, if you contact a dealer for repair parts, you will pay for them (i.e. 40.00 US for a bearing). I recommend bringing your old bearings and seals to a local bearing distributor, if you have one in your area. They can mic the bearings and get you the correct seals etc. That's what I did with my pump and had no problems whatsoever. Finally, another thing I did was go to a boat salvage yard and buy another pump. I overhauled it and use it as backup so I can swap the pump out if a seal or bearing fails. Good luck!
BZ"
