seamaxx 5.8 ford temp question
hrofordpower
I have twin 5.8 fords an d both will run at idle at 170 degrees. The starboard motor will run up to 180 while the port stays at 170 while planing. Is this normal? I've rebuilt the sea water pumps cleaned the heat exchangers put new manifolds and elbows. I've also put a new gauge sender and wiring to the gauge in.
thanks Chris
